Help with reserve ip w/ DHCP
The instructions say
" Easy way
Devices may be found in the Devices table when they are connected to the network. Click the settings cog under that device’s Name column. In the new panel, you can configure the client’s details.
I can not click on my COG. If i click the name or icon a windows comes up but when I save it warns this will effect all items on this port.
Help would much appreciated. Also I cant find a wiki, doc, manual for route10.
Wow, found a hidden item.. If you go do IP/Mac binding “the hard way” where you click IP,
there is what looks like a copy/paste button..
It let you paste in or create a import of more than 1 ip to mac.. That should not be hidden.
It’s documented in the static IP guide
Help/Wiki is part of the Alta Labs Help Center knowledge base, search for Route10, and there are a few topics.
Alta Labs Help Section: Route10
Link to the actual doc: https://help.alta.inc/hc/en-us/articles/35073566347803-How-to-Reserve-DHCP-by-MAC
