I am building a new house and planning to use Alta Labs APs for my network. I am good on all of my other hardware (router, switch, etc.). Any suggestions on best placement for my APs given my floor plan. I’m adding pics of my 1st & 2nd floor plan. There is also a 3rd floor that has apprx. 500 sq feet with a bedroom and full bath. The house is a standard rectangle shape with studs and drywall construction.
The 1st floor is ~1600 sq ft.
The 2nd floor is ~1800 sq ft
The 3rd floor is ~500 sq ft
I was thinking the following:
1 AP6 on 1st floor near back of house to cover rear porch as well
1 AP6 on 2nd floor maybe in central hallway
1 AP wall or ceiling unit on 3rd floor
Key questions:
- Recommendations on placement of POE+ APs and how many - is my initial thought above OK or is there a better approach?
- Will 1 AP per floor be enough or too much - especially on the 2nd floor given it is 1800 sq ft?
- Will an AP on the first floor near the back of the house create a need to have one on the front half as well to cover the front rooms and the garage?
Thanks for any input on this.
