Frustrations with Alta Hardware Controller and Route10 Setup: Feedback, Issues, and Questions
Hi Jeff, yes I was able to resolve this issue as I mentioned above. but this is marked as future request for " Include an option in the initial Route10 web-based setup wizard to customize the LAN IP range (e.g., 10.0.x.x)** alongside the WAN configuration."
But I am good to change the type and mark as resolved, but I am unable to edit my initial post. could you advise.
@prmadhava We were able to resolve the issue with editing your post, so feel free to edit your original post now. Since this post has covered quite a few things, feel free to make another post that focuses on initial subnet configuration, and we’ll keep you updated when that feature is ready there.
interesting I still don’t see an option to edit
Can you see the pencil to the right of your post? I assume you are logged into the same account that you made the post with.
Sorry about the confusion here. It should work now though. Can you please check again?
I’ve moved your post to another category, as it has become convoluted with troubleshooting such that it no longer resembles a feature request.
Can you repost your feature request with the more limited scope of just the feature you’re requesting?
Totally concur with the requirement to have a standalone local UI.
Could you also repost this in the feature request category? There may be a thread already for you to add your vote and a comment as well.
It seems the 1.0.0.0.1 subnet issue persists despite your attempts to configure it, mainly due to limitations in the router’s initial setup process. A suggested improvement would be for the setup wizard to include an option for users to specify the LAN IP range upfront, reducing the reliance on the mobile app and simplifying the integration process. Additionally, the cloud dependency for hardware controller activation could be reconsidered to align with the expectation of an independent setup.
Configuration of the “VLAN1” main subnet is already a part of the wizard, as well as even an optional second management subnet configuration, as long as you are on the latest Route10 firmware release.
