Forum Multi-Factor Authentication
I’m digging the Purple, black, and white theme!
I poked around and can’t find out where to enable MFA – am I looking in the wrong place or is it not enabled?
Thanks!
@Matt I figured out the MFA – but can we put it on the Forum side instead of the controller side or has some sort of notice that tells folks to go the controller to enable MFA?
@Willie_Howe we use the same authentication for the device management / controller platform, and the forum, and the upcoming helpdesk … so the SSO authentication will be the same.
But I see what you’re saying … let me pass this on to the team.
Thanks for the feedback!
-Matt
@Willie_Howe for now the best way to enable MFA is through the controller platform. And we’ll do a better job making that clear to users, and maybe improve the UX a little … but thanks for pointing this out!
Is MFA only supported on local controllers? I do not see away to enable MFA on the cloud controller at manage.alta.inc on mobile.
I’d like to suggest MFA implementation sooner rather than later and to implement passkeys are a form of login and not just 2FA
