When you have 100+ devices per site with multiple switches on one site it would be nice to limit view of devices per switch or AP. Just a toggle/filter to select a Device (Switch-n-location) and the see only devices connected to that one would be really helpful.
You can also see the connected devices in the Info tab of any AP configuration pane, or the ports graphic of any Switch configuration pane.
You may also sort the Devices list by the Link column. Add the column in the Options menu if it’s missing.
A filter and search feature could still be useful, I agree.
Thanks, yes we know about this options but a “bigger” view is sometimes needed ![]()
The map feature may also fill in the gap until a more dedicated search could become available.
Yes
but 100+ devices
. Hope this gets implemented.
