Does AP6-Pro has wider coverage
Does AP6-PRO has wider coverage than AP6 at 2.4GHZ. My camera keeps droping from internet with AP6.
As far as I know, there are no differences in the specification for the two versions regarding 2.4 GHz band WiFi.
Check specifications at:
Edit: Radiation patterns may not be exactly the same, though differences should be small.
Could you try lowering the air time efficiency threshold, please?
To do this:
  1. Go to Settings
  2. Go to WiFi (it’s the default so you’re likely already there)
  3. Click the SSID the camera connects to
  4. Expand the Advanced section
  5. Set the 2GHz Air-Time Efficiency to Manual
  6. Move the slider all the way to the left
  7. Save
After doing that, monitor for a bit and let me know if that cleans it up. What signal is being displayed for the camera under the Devices tab?
