Disable browsing to gateway
Is there a way to disable browsing to the gateway IP on a particular VLAN? Right now if I just browse to the gateway IP I get a page that says “This device has already been configured…” Would rather it not be accessible at all.
You can set the source address to the subnet of your VLAN for a firewall rule, then block http/https traffic over ports 80 and 443. I don’t know if this may cause other issues yet, so your mileage may vary.
