Devices all over the place
Hi,
Seems the Devices doesn’t handle VLAN changes
The link, CH/Port and VLAN all seem to randomly change
IP’s dont update from old Ip to NEW.
Some even show VLAN6 on a CAT5 cable that is on VLAN 210
Can i clear the cache somehow?
Thanks !
The client devices gui is is not fully functional ip addresses don’t sort. as you say speed of updates and changes to io , vlan , Mac/ip mappings. are hit and miss. had the router lock up, vlans chamge on the Lan ports.
The. VLAN column seems to show a index number 1,2,3,4. instead of the actual VLAN id.
yer, some are showing correct VLAN ID.
Lets wait for the fixes in updates…
Thanks !
Guys they are going to need really specific info about this problem. We generally are not seeing VLAN issues in daily testing. Can you please post about what VLANs you are using and what the configs look like?
I have a seperate post detailing the issue VLANS etc
Seems to be OK this morning.
Dash is much more stable and the data is all correct this morning.
