Hi all, have 2 Alta 8 Port switches and 2 Alta AP6 Pros connected to each switch.
Here is a summary of my physical topology:
Switch 1 Port 1 - Connected to Uplink (Device is a router)
Switch 1 Port 2 - Connected to AP1
Switch 1 Port 3 - Connected to AP2
Switch 1 Port 8 - Connected to Switch 2 and used as Uplink for Switch 2
Switch 2 Port 1 - Connected to Switch 1 Port 8
Switch 2 Port 2 - Connected to AP3
Switch 2 Port 3 - Connected to AP4
Here are my network details:
VLAN2 - Guest Network
VLAN3 - Device Mgmt VLAN
VLAN4 - Guest 2 Network
VLAN10 - Internal Network
SSID1 - Internal Network
SSID2 - Guest Network
SSID3 - Guest 2 Network
All MGMT VLAN on my switches and APs have been set to VLAN3.
On Global Switch Config I have also allowed VLAN 2,3,4 & 10 as well.
In switch 1 switch port configuration:
Port 1: Native VLAN3, Allowed VLANs 2,4,10
Port 2: Native VLAN3, Allowed VLANs 2,4,10
Port 3: Native VLAN3, Allowed VLANs 2,4,10
Port 8: Native VLAN3, Allowed VLANs 2,4,10
Switch 2 Switch port Configuration:
The issue i’m facing now is that services are up and all 3 of my SSIDs are all able to be broadcasted and I’m able to access the internet when connected to it. However, on the controller, all my devices are showing offline. What could possibly be the issue?
