Is this restricted to 1 or can an existing management vlan be used? Don’t want to take the system down accidentally. Thanks!
By default it’s the untagged VLAN, so could be any VID technically, but we also refer to it consider it 1 (it’s VID 1 on Route10). They will need to be setup on an untagged VLAN, but once in Control you can go to settings and define the VID of your preferred management VLAN (same location to set a static if desired).
It’s in the same location on an AP or switch. Open the device properties card, then go to Settings. It’s right there at the top. Adjust as preferred.
This might be more of a feature request thought, but would there be a way to define what “default” means on a site? I don’t think there is off hand, but figured I’d ask since I’m thinking about it ![]()
