Hi Alta labs! Thanks for bringing another high quality lower cost solution to the market! Very simple and fast and can set up a WAP in like a minute. Way better experience so far than the other. Im not sure, looks like not an option to do a custom timeline for data throughput history. Just see live, 1 hour, 2d, and 2m. It would be very helpful if there was a customizable time period and or 1 month instead of 2. Also for us hotspot 2.0 folks the ability to see throughput history by ssid. We vlan our traffic for the hotspot 2.0 connections and would like to be able to monitor someway how much traffic is flowing through in a givin time period. Instead of just all traffic from all ssids. 2 weeks would be another cool one to add. Anyways wanted to pass this along to Alta labs and keep up the good work! Also if I got a ap6-pro new from one of your authorized distributors and the led doesnt work but the wap works fine otherwise should i rma it? I tried factory resetting twice, its updated.. just not sure if I should be worried that its a sign of failures to come…
@TOM5 Thanks for the feedback! I’ve never seen an AP with a failed LED so that would be a first. All you need to do is reach out to support, though, and they will take care of you ASAP.
