Coverage heat-map tool?
Hi guys,
I have just swapped out a few Ubiquities for AP6-Pros and would like to do a review/comparison of the coverage.
What tool do you recommend (preferably free if that exists, or not that expensive) that I could put a drawing of my building and see before and after? Still have the Ubiquities laying around so could plug-them in again for an hour or so and walk around and do this heat-map-thingy…and then quickly back to Alta again! :wink:
Thanks!
A few users have recommended Acrylic:
Or Netspot:
But there are quite a few out there :slight_smile:
Let us know how the comparison goes!
Im reviving this thread from a year ago not to start another one. Is there any update from Alta on planning to release a tool made by yourselves? Or at least a compatibility with another tool that I could load the radiation diagram of your APs or heat map and simulate a deployment?
Hamina has the Alta products loaded and is a partner with Alta. It might have what you are looking for.
I have used it to do a site survey and add Alta for heat maps.
Ah great! Will try it!
@Jorge Coming soon! Only a few more weeks now, I suspect. Its looking great!
Awesome news!
