Control not able to set settiing on route 10
Just starting to setup my control and route10 and wanted to go into settings. When i am in the network tab and click on the icon for the route 10 i get a pop up that says settings. If i click it it does nothing. Also shows no other info. Have i done something wrong during setup or what is going on here.
the router is updated to1.4i wanted to check the control as well found the button that say check but unsure how to tell its version.
I finally figured it out the control was having issues updating, after factory default reset i was able to update the Alta control and everything seems to be working as intended.
