- Local: Add support for TOTP MFA Authentication
- Local: Add support for Passkey (+MFA) Authentication
- Local: Add support for custom certificates
- Local: Add support for disconnecting from Alta Cloud
- Add support for Backing up and Restoring sites (including granular options)
- Switches: Add support for Layer-3 Routing
- Switches: Add support for Layer-3 ACLs
- Switches: Add support for DHCP Server and Relay
- Switches: Add support for network-wide MAC to VLAN mapping
- Route10: Add support for DHCP Relay
- Route10: Add option to enable UDP acceleration
- Cloud-only: Add beta support for AI Diagnostics
