WiFi: Add support for disabling individual passwords
update to 1.2d and try to upgrade to 24.04 on my proxmox lxc container issue on restart
Need to add features nesting=1 (pct set XXX -features nesting=1) and reboot container
Config for info
pct config XXX
arch: amd64
cores: 1
features: nesting=1
hostname: AltaControl
memory: 2048
net0: name=eth0,bridge=vmbr0,gw=192.x.x.x,hwaddr=BC:XX:XX:XX:XX:XX,ip=192.x.x.x/24,ip6=auto,type=veth
onboot: 1
ostype: ubuntu
rootfs: local-lvm:vm-xxx-disk-0,size=8G
swap: 512
@Julnobugs Please make sure you are logged in as the controller administrator. We will resolve this so that the button is only available to controller administrators in the next release.
@Alta-Jeff: I’ve only one account that was initially used to setup controller and devices. If I go in Settings\Users I can see that my account is having full rights/permissions. Do I miss something ?
There’s very likely some other email that you had used when originally setting up this controller, if you can try to remember. Either way, please invite me to your controller, I’ll send my email separately.
Invite send.
A year and half ago, I did hit a bug with a special character + in the email and was unable to login after initial deployment. Retrying from scratch with an email without this special character did the job, I was able to full administrate the site and the route10 since then (no permission restriction): Altra control vm deployed locally but unable to Sign-Up - Alta API Back-End Crash
