- WiFi: Add support for manual mesh uplink selection.
- WiFi: Add support for assigning connection profile based on device MAC.
- Route10: Add support for port aggregation.
- Route10: Add support for Tailscale.
- Route10: Add support for PBR routes over WireGuard VPN connections.
- Switches: Add support for enabling/disabling ports based on a schedule.
- Add support for custom update windows (Settings->System).
- Topology: Various logic improvements.
