Control 1.1x Released! (cloud & on-premises)
This update to Alta Control delivers expanded visibility, control, and usability across the platform, with enhanced Route10 monitoring and policy management, improved audit and troubleshooting workflows, more flexible topology and WiFi management tools, and broader platform reliability improvements.
  • Network: Show exact time of last device connection.
  • Network: Show devices that have been added via Serial Number.
  • Topology: Add support for vertical layout, in addition to horizontal.
  • Route10: Add PBR fallback and drop targets.
  • Route10: Add support for VPN Client statistics.
  • Route10: Add support for AltaConnect connection status.
  • Route10 IPS: Add support for configurable categories.
  • Route10: VPN IPsec: Allow modp1536 in DH group config.
  • Audit Trail: Improve Group event messages, including showing deleted group names.
  • Audit Trail: Add support for searching and export.
  • WiFi: Import/Export passwords.
  • WiFi: Add filter option to open/enterprise SSIDs.
  • WiFi Filters: Allow showing only current site.
  • Update Alta Device Icons.
  • Add KB article and Youtube links throughout platform.
  • Resolve issue with setting up Alta devices on controllers behind reverse proxy.
@Alta-MikeD Hi Mike, I am grateful for all the improvements; however, I need your help. I am seeing new icons for the AP6-Pro, Route10, and S8-POE, but not the Control icon.
How can I get this to work? Can you help?
Additionally, why am I seeing Control in the Devices section rather than the Network section? Is this normal?
It would be a cleaner look and feel to have all Alta devices under Network with the appropriate icon, don’t you think?
Speak soon,
-Luke
Hi Luke,
Sorry for the delay. We do have plans for both, although we don’t have a timeline to share yet.
At the moment, Control appears in the Devices section rather than Network. We agree this creates an inconsistency, since Control is currently the only Alta product that doesn’t appear alongside the rest of the Alta infrastructure products.
We’re planning to address both the lack of a dedicated Control icon and Control’s presentation within the controller, though we don’t have an ETA for either change at this time.
Cheers,
Mike
Hi Mike,
Grateful for your reply.
I am sure you will agree that perception affects perspective. I am not alone on this matter and I have ask about this in many episodes ALL, and connot see why low priority is being placed on the UX/UI to the UI reflect device accuracy in the Ntwork and Device tabs
The devil is in the details and we have waited for a long, fixing these issues reflects that Alta care s about quality and polish for the UX/UI. So, can we make it a priority?
The little details creates the impression of polish and completeness. These quirks should have be sorted from day
Aside from the Control device not showing up in the Network tab, are you seeing any other UI/UX polish that needs work?
Jeff,
I’ll talk back to you in 3 years. I will leave this matter to time. Let’s see what happens in then.
Based on our rapid release cadence, things will likely be very different then. Have you checked out some of our latest features for schedule profiles and scheduled filters?
Jeff,
As I said to Mike, I asked;
Why am I seeing Control in the Devices section rather than the Network section? Is this normal?
I think a quick Win for Alta is to resolve what I asked Mike in the quoted question.
Sorry, the reason why we haven’t done that yet is because it’s not as quick or as easy as you may believe, and technically it is just another client on the network - honestly it could go both ways - network or devices; perhaps we make it an option when we do implement that? We’re happy to take a look at any other issues you may be having, though.
I see.
