This release introduces AltaConnect, enabling automated site-to-site connectivity across Alta Labs deployments. It also expands WiFi policy flexibility with support for multiple filter profiles, alongside enhancements to device management, switching visibility, and system performance.
- WiFi: Devices: Show Password Note in addition to index.
- WiFi: Add support for multiple filter profiles per password, voucher, profile, and client.
- Route10: Add support for AltaConnect.
- Devices: Show switch ports’ colors on Devices list (in addition to APs’ colors).
- Improve telemetry processing efficiency, particularly for very large sites.
- Devices: Add support for batch setting DHCP, MGMT VLAN, and rebooting.
- Devices: Show total PoE power consumption on PoE switches.
- Firewall Rules: Add click and drag support.
- Resolve issues with restoring from older backups.
- Topology: Work-around issues with cyclic connections from unmanaged switches.
Note: Version 1.1v supersedes a previously tagged 1.1u build which was not broadly released.
