Control 1.1t Released! (cloud & on-premises)
This release introduces a new full-screen view for switch port visibility and includes fixes to improve WAN port classification accuracy.
  • Add Switch Ports Table full-screen view (Table icon from Network Device list, or Device Window).
  • Resolve issues with WAN ports showing as tagged LAN.
This is constant after updating.
Google Chrome Version 147.0.7727.56 (Official Build) (64-bit)
On chrome, start a new tab and open your site, it takes several seconds now. When it finally loads, open a few other unrelated tabs for various sites. Focus on an unrelated tab for a few minutes then go back to your alta site tab and this continues.. It’s non stop.
We cannot reproduce this here. Do you have any browser extensions? What OS are you using? Can you share the developer console log?
Cleared out the site data which seemed to resolve the issues. I guess another task to add to the never ending amount of tasks with this platform post update.
I am now unable to access the dashboard intermittently. What are the processes to downgrading back to s revision?
I know you won’t like the answer, but it would be best if you can reach out to support@alta.inc to invite them to the site to grab more information on why you can’t access the dashboard intermittently. We are not seeing anything like that in our testing here, but working with support will be the fastest way to make sure this gets resolved ASAP.
