Control 1.1q Released! (cloud & on-premises)
This release adds new security and performance controls, enhances device monitoring and audit visibility, and improves configuration validation and reliability across multi-WAN and VLAN-rich deployments.
  • Add support for Alta device disconnection webhooks.
  • Add support for Alta device update audit events.
  • Switches/Route10: Add support for displaying SFP DDM metrics.
  • Route10: Add support for Firewall Groups.
  • Route10: Add VLAN Acceleration option (for sites with more than 5+ VLANs).
  • Route10: Resolve load-balancing configuration issue with more than 2 WANs.
  • Route10: Add support for inline Intrusion Prevention mode.
  • APs: Add warning when 100 Mbps uplink is detected.
  • APs: Add mesh/fallback enable/disable to batch edit.
  • Add several more client device icons.
  • Add validation checks for Device, VPN, and VLAN IPs, to avoid duplication.
I’ve always wondered why there is an icon for Airpods. They can’t connect to WiFi. :laughing:
