From improved usability to deeper insights and new integrations, this Control release focuses on the details that make the overall experience better.
- WiFi: Enable Fast Roaming by default for new SSIDs.
- Terminal: Fix light mode, and add ability to resize window.
- Topology: Resolve issues with WAN devices being on the incorrect side of Route10.
- Add support for viewing wired-only or wireless-only DPI statistics.
- Add support for PSK Offload setting, for use with providers like RoamingIQ.
- Users: Add ability to disable invite email being sent.
- DDNS: Add Dyn.com provider.
- Various bug-fixes and improvements.
