Control 1.1d Released! (cloud & on-premises)
Big news—our latest Control update is live. Here’s what’s new under the hood.
  • Add support for disabling SSIDs.
  • Add support for S48-APOE and S12.
  • Firewall: Add ability to disable rules.
  • Improve support for AP6W.
  • Improve wired device uplink port logic.
  • Improve Device CH/Port and Signal strength sorting.
  • Improve device window layout, showing uplink switch and port settings.
  • Resolve issues with disconnected wired devices not showing as disconnected.
  • Resolve intermittent issues with topology of some wired devices.
  • Resolve issues with copying sites.
  • Resolve issue of RADIUS server intermittently not getting configured to switch.
Question.
Are you able to expand on the AP6W support? Are we able to manage those AP’s locally or is it strictly via cloud until further notice?
The local controller has parity to the cloud controller as far as AP6W support goes.
So if I’m understanding correctly, the AP6W product cannot be set up and managed by Alta’s local controller, we’d have to set up the AP6W over the cloud and manage between cloud and local controller?
No, the local controller can set up and manage an AP6W just like the cloud.
