Control 1.1b Released! (cloud & on-premises)
The latest Control update is now live across all deployment types. Please see below for the release overview.
  • WiFi: Add note field to PSKs.
  • Improve conflicting IP address detection.
  • Route10/DDNS Client: Add public IP option.
  • Improve controller stability.
This update is being rolled out now. You can manually initiate the upgrade if you’d like, or it will automatically update overnight. Here are the full running changelogs for both platforms:
Overall, great work.
The following issue may possibly have been introduced in 1.1b:
Edit: Problem solved by rebooting the HW Control device. Strangely, I had it rebooted a couple of times before while re-arranging ethernet cables in the network rack, so I didn’t think another reboot would make any difference.
I’ve had to restart docker container after other control upgrades. It would show the right version, but functionality wouldn’t change until restarting.
