Control 1.0u Released! (cloud & on-premises)
The latest update to Control has been rolled out, bringing refinements and new features to support both cloud and on-premises environments. This release includes:
  • Route10: Add support for WireGuard VPN client
  • Route10: Add IGMP Snooping option
  • Route10: Add alternate hardware acceleration option
  • Route10: Resolve IPv6 PD prefix provisioning issue
  • Switches: Add flow control configuration option
  • Add Reboot button under Advanced options
Here are the full running changelogs for both platforms:
What is the default Flow Control behavior?
It is default disabled on our current switch models (at least on versions 1.0u/2.1s).
Why is Alta pushing firmware updates upon Alta Control units that have automatic updates settings set to off. I find this a bit disturbing. It is up to me as the end user to update any devices on the network I deem fit, especially a locally managed network, not Alta.
Hmm, that sounds like unintentional behaviour. Disabled is supposed to be respected. This is the hardware Control and not a container installation, correct?
This is the Alta Hardware Control.
Additionally, the LED color on the Alta Control continues to reset to Aqua after each reboot. Clearly a bug.
I agree with the LED color bug. However, I have not ever seen it auto update when that is disabled. That one seems like it warrants further investigation.
I saw the docker controller update when auto updates were disabled too.
Mike, I apologize for being blunt, but whether it’s unintentional or not, it shouldn’t have happen.
