Control 1.0r Released! (cloud & on-premises)
The latest Control release is now available, supporting both cloud and on-premises management. This update includes the following enhancements:
  • Route10: Add IDS/IPS Support
  • Improve modal icons
Here are the full running changelogs for both platforms:
Updating now!
Bug: Local Alta Controller is still being assigned turquoise after Route10 reboots. The LED settings are set to the default white. I’m sure controller related more than anything.
*Moved from Route10 release to Controller release post.
Very happy new year!
Bug:
I updated my route10 to 1.3s from cloud control on my pc browser. I then opened up the mobile app and saw there is an update available. I did it and then my route10 got downgraded to 1.3r. After I updated it again from the browser, I restarted the mobile app and the issue was resolved.
Hey!
Is there a way you can update the docker images? I’ve planned on setting up a controller but it seems there’s only 1.0d available https://hub.docker.com/r/altalabs/control/tags
I’m running my stuff on Kubernetes, so lxc is not really an option
Once you have the container up (on 1.0d), click on Setting → System, and then the check for updates
Is the update persisted in a data directory? I might have containers recreated quite frequently (moving to another node, scheduled updates, …)
