CCTV with Alta Labs
Hello,
we have some lagre CCTV projects coming up next month and between two building we need to put one NVR in the main building and wirelessly bridge to the second building using a point to point access points.
Will the AP6 outdoors device allow this? on the second building there is 5 cameras we need to transmit from.
Thanks,
Joel
Sure that should work great as long as it’s line-of-sight and less than 200 feet distance.
