CAKE not working for WiFi device when only download limit is set
While contemplating on the discussion here
I found that setting an upload limit only did not actually make any difference on speed and bufferbloat tests for the download part for my WiFi Android device (OnePlus 10 Pro).
The download is affected first when I set the upload limit as well.
The corresponding tests (running manually installed speedtest) from the Route10 itself shows up with and without speed reduction and latency improvements as would be expected. See here: https://forum.alta.inc/t/hardware-acceleration-issues/4156/21?u=ebuckland81
Results from Waveform for Android WiFi device:
Nominal...
With CAKE 602/-, i.e. download set, upload left blank...
With CAKE 602/602...
Any ideas? I guess this is not expected behavior for a network client device…
Edit: A few minutes later, I realized this may be related to another very recent issue. Seems like this was related to the Hardware acceleration setting for the Route10 WAN port being out of sync. Toggling the setting, Enabled → Alternate → Disabled → Enabled, seems to provide sensible results again. This was noted here as well, though with different outcome/symptom:
and
So, problem solved for me, but still something to investigate in terms of why the Hardware acceleration setting gets out of sync while applying CAKE settings, and why it only adversely affects the network client device and not the Route10 itself.
Oh, well, unfortunately I came to conclusions to quickly…there were more to it. It’s a fair bit mind boggling, so bear with me.
Settings for download limit only, with Hardware acceleration setting left at Enabled (after some fire-at-will-toggling as per the initial post) did not survive a reboot of Route10 and AP6 Pro. Speedtest results for my WiFi Android device are back at nominal, which is not expected with CAKE download limit only set.
Now, things get a bit out of hand…When trying to toggle Enabled → Disabled → Enabled it does not work as intended back at Enabled. Only the setting Disabled leads to CAKE being properly functional on the download side.
But, when passing Alternate on the way back from Enabled, it works on Enabled. However, this does not survive when toggling repeatedly Enabled → Disabled → Enabled.
Then, when passing Alternate on the way to and from Disabled, it works back at Enabled and also repeatedly survives further toggling back and forth between Enabled and Disabled. I have repeatedly reproduced this behavior for consecutive reboots.
Once again, all for the CAKE download case only. And, just to mention, I waited some 15-30 seconds between each settings change, and also added a speed test after each change.
Also, I noticed that the setting for upload limit only works as intended (as well as upload and download combined). And it doesn’t get impacted by a reboot either.
So, summing up the findings for your further troubleshooting:
  • CAKE works as expected at Route10 level.
For WiFi client:
  • CAKE upload and download setting together works as intended.
  • CAKE upload setting only works as intended.
For WiFi client, download setting only:
  • CAKE download setting only is no good with a prior Hardware acceleration Enabled/Alternate setting.
  • A fix is to toggle the Hardware acceleration setting to Disabled (but is probably unwanted as I guess it might come in handy for the upload part?!)
  • A temporary fix is to toggle Enabled → (Alternate → ) Disabled → Alternate → Enabled.
  • The temporary fix does not survive a reboot.
WAN is set to DHCP by the way.
@Alta-MikeD, did you manage to reproduce and get to the bottom of this. :slightly_smiling_face:
I had a minute to do a quick test and to my eyes it looks like CAKE just doesn’t function if only the download limit is set. Seemed to no longer be limiting with any devices, including a wired device. That being said, I feel like the scenario where setting only the download limit would be an odd one, but in theory it should work just fine (at least to the best of my knowledge).
I didn’t get a chance to test with hardware acceleration disabled but I believe hardware accelleration gets disabled for WAN traffic when CAKE is turned on anyway. That might be part of what underlying issue that we’re seeing, if I had to offer a semi-educated guess.
I kind of thought the same initially, but then got the idea from @63fd404ac5d0c614d505 to only limit download, and after all I found it quite promising. Basically, in my case, limiting download only will improve download latency while not capping the upload max speed and touch its already superb latency.
So, it should preferably do this but maybe it doesn’t happen automatically in this case. I had to manually switch the hardware acceleration setting as per the steps as described above to get it working and persist reboots.
That’s fair! I know some ISPs already put some shaping on upload to keep latency in check, so that definitely makes sense to me.
Correct, as I recall it’s specifically for WAN traffic since the shaper won’t see the traffic if it’s running through the hardware acceleration. That way hardware acceleration remains on for all other traffic coming through the router.
To me it certainly sounds like download only is a scenario that’s not being flagged for that automatic exeption to the hardware accelerator. But I’m happy to be corrected by someone from Alta if I’m making a bad assumption there :grinning_face:
