When you block a device from all networks using the block button, it takes down the entire wifi system for a few seconds. All devices disconnect momentarily for ~5-10 seconds. Is this expected behavior? Shouldn’t it just “kick” that client and not allow a further reassociation and not take down the whole wifi network?
Hey @benmott does this happen every time you try? I can’t seem to replicate that here …
Yes, every time you block and unblock a device it causes the wifi to drop and reconnect.
