Blocking Device From Network(Wifi) doesn't work or immediately kill the connection
I’m trying to manually block a couple devices from connecting the the internet on-demand, however after blocking them, the end device still seems to be able access internet(Even after a router reboot) and it was able to reconnect to the network without any issues.
Above is a blocked device that’s still has live internet traffic
I’ve also tried Applying temporary schedule to stop internet access of all times, it seems to do nothing as well as setting upload and download limits to low number(0.1mbps) doesn’t seem to work either, not sure if this is something to do with my configuration or a bug
After some testing, blocking device seems to work only sometimes, where after clicking block internet access button, the device can no longer connect, but other times the device is still able to access the internet
Definitely check with support on this one, but I think that block might mean the next time the device tries to connect to the Wifi, it will not be allowed to connect.
Hmm, I thought that as well, however after a router reboot and a force wifi disconenct on the device, it still seems to be able to connect even when blocked
