Apple Devices Trouble With WPA3
Just installed a AP7 Pro so I enabled WPA3 for WiFI 7/6Ghz support. Some iPhones took a few tries to connect but 1 refuses to connect with WPA 3 on. Same with an Apple TV 4K. The second WPA 3 is disabled boom it connects turn WPA 3 back on and it won’t. All these devices are current generation Apple TV and iOS devices so I’m confused as to why some are having issues with WPA 3 and others after a few tries I finally got connected.
Edit PMF doesn’t enable by default with WPA3 but it is required for WPA3. Make sure to switch that to on if it’s not to avoid issues.
Make sure you also have PMF enabled, if you are enabling WPA3 on 2/5 GHz.
This solution fixed all my apple stuff at home & windows..
Suggestion but maybe have the UI enable PMF by default when WPA3 is enabled since it’s a requirement of the standard. I overlooked that for so long and never knew why things were all wacky.
^^^^ this.
