Has anyone ever experience an AP6W with red or green LED?
I’m currently in the middle of a network install with 1 AP6 ceiling mounted and 14 AP6W connected to existing cabling throughout the building.
My process is thorough. Locate port number in the room and at the patch panel. Test cable using fluke network tester, fix errors if any and then mount ap and patch through to poe switch.
I had one at the end of day today that tested perfect but, when I patched it through it came up with red LED. I disconnected it and put in a new patch lead and it came up with green LED!
I have installed hundreds of Alta gear and have never seen anything like this. Looking some advice or if anyone else has ever experienced the same.
Cheers
Coly
