AP6W Port Question
Hi all, I was wondering if someone would be able to shed some light on the ports of the AP6W AP. If I use port 3 on the rear of the unit to power the AP over POE can port 1 or 2 be used as a LAN/Data port to downstream to another device?
Hi! I made a video testing this unit, and I was able to connect the S8 to port 1 or 2 of the AP6W, then use it to connect more devices afterward. It’s a pretty neat device because it not only provides Wi-Fi but also gives you access to two additional ports if you power the AP6W through port 3.
Thanks for that, I thought it would be possible but just wanted to double check before taking the plunge.
