AP6Pro Outdoor Range
I’ve seen the post with the AP6 Pro Outdoor review, but my question is around real-world range.
If the AP is mounted on the outside of a building and you walk directly away from it in a clear line, roughly how far would you expect the signal to reach? Would it comfortably cover around 40m / 130ft?
The map below shows the proposed AP location and the proposed locations of the static cameras, marked with X.
I’ve achieved this before using another manufacturer’s equipment, but I’ve moved this client over to Alta gear and would like to keep it that way if possible. :slight_smile:
I don’t think you will be able to get power if you use 5Ghz. Maybe 2.4Ghz, but I think the signal can be low down the field. Can you push AP futher on the field or closer to it ? Because it would be clear line between AP and devices, but the concern is the distance.
We have easily used an AP6 Pro Outdoor access point up to 520 feet with both 2.4 and 5 Ghz bands.
Thanks for the information. That’s interesting to know. It sounds like I’m just gonna have to get down there and try one.
Testing is the best bet. Too many environmental variables to consider. RF Noise will be a big factor.
