AP6 Pro upgrade error "Curl error 56@
My Alta labs kit has been in storage for a couple of months whilst i relocate to a new property. Today I have internet and connected the route10 to the network behind the ISP ZYXEL router. The Route 10 joined the network and upgrade to the latest firmware available. I then added an AP6 Pro to the route10 and again it was discovered but steadfastly refuses to upgrade to the latest Firmware. It gets to about 0.9% and fails with the above error. I have pressed the reset button on the AP whilst connecting the Ethernet cable and counting to 7 slowly. However it will not upgrade and keeps throwing the Curl error Any assistance would be greatly received.
Thanks
Hello Don!
That error is most likely related to the fact that you might have same IP network scheme on your LAN and WAN.
For example, If your Route10s WAN connection is on a 192.168.1.X network and your internal network is on the same one, this will cause routing issues and will also give you that error.
