AP6 Pro - Guest Isolation?
Hi Guys, stupid question but is there guest isolation with speed configuration in the cloud controller?
I must be blind but any help is appreciated. thanks!
After some looking around randomly, i stumbled upon the password settings which does have various scenarios. I wouldve never intuitively found this for Guest Isolation.
I’m guessing Guess Isolation is “Internet” only for Alta’s equivalent?
Yes, there are actually two types of guest isolation: Guest and Internet-Only.
Internet-only will only allow communication between the Router and the Device. Guest is similar, but also allows communication with IOT devices on the network, such as printers or streaming devices.
You don’t need to enable anything else like port/client isolation, inter-AP isolation, multicast blocking, etc. since these network types take care of all of that for you.
