AP has constant disconnections on ethernet interface
good day to all
A few days ago I received in my country (Uruguay), my new Alta Labs S8-POE with an AP6 pro to replace my aruba 303.
I configured and upgraded the switch correctly, connected my aruba 303 to the switch without any problem (it is still connected because I have not been able to solve the problem that I am going to tell you).
Once the switch was configured, I connected the AP6 Pro, it appeared in the cloud console, I upgraded to version 2.0j and configured some vlans to the port of my switch to use them in the access point.
However, I start to notice intermittency in the connection, when I see the status on the switch port that connects to the access point, I notice that the loop icon appears, however, it is a very small home network and I can assure 100% that there is no loop of any kind.
I have tried factory resetting the AP 3 times with no effect, I have also tried disconnecting the switch and putting the AP directly with a PoE injector and the same behavior is replicated. I have also tried removing the vlans completely and having it work on a flat network with the same effect.
I logged in via ssh to the access point and found that some script is restarting the network service, I leave here the logs that I took from /var/log/messages.
Thank you in advance for any help you can give me.
Mar 27 01:22:22 OpenWrt daemon.notice rc: [2024/03/26 22:22:22:7826] N: __lws_lc_tag:  ++ [wsicli|1|WS/h1/default/manage.alta.inc] (1)
Mar 27 01:22:22 OpenWrt daemon.info procd: Instance https-dns-proxy::instance2 s in a crash loop 428 crashes, 12 seconds since last crash
Mar 27 01:22:22 OpenWrt daemon.info procd: Instance https-dns-proxy::instance1 s in a crash loop 428 crashes, 12 seconds since last crash
Mar 27 01:22:22 OpenWrt daemon.info procd: Instance https-dns-proxy::instance3 s in a crash loop 428 crashes, 12 seconds since last crash
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: 8021ad
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: 8021q
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: macvlan
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: veth
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: bridge
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: Network device
Mar 27 01:22:23 OpenWrt user.notice : Added device handler type: tunnel
Mar 27 01:22:23 OpenWrt user.notice https-dns-proxy: Starting service βœ“βœ“βœ“
Mar 27 01:22:23 OpenWrt daemon.warn netifd: You have delegated IPv6-prefixes but haven't assigned them to any interface. Did you forget to set option ip6assign on your lan-interfaces?
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'trunkiface' is enabled
Mar 27 01:22:23 OpenWrt kern.info kernel: [ 2579.085610] br1: port 1(eth0) entered blocking state
Mar 27 01:22:23 OpenWrt kern.info kernel: [ 2579.085644] br1: port 1(eth0) entered disabled state
Mar 27 01:22:23 OpenWrt kern.info kernel: [ 2579.109371] br-lan: port 1(eth0.200) entered blocking state
Mar 27 01:22:23 OpenWrt kern.info kernel: [ 2579.109408] br-lan: port 1(eth0.200) entered disabled state
Mar 27 01:22:23 OpenWrt kern.info kernel: [ 2579.110833] device eth0.200 entered promiscuous mode
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'lan' is enabled
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'lan' is setting up now
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'lan' is now up
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'lan6' is enabled
Mar 27 01:22:23 OpenWrt kern.warn kernel: [ 2579.128355] vlan200: ip10.0.200.21 (ifa)
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'loopback' is enabled
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'loopback' is setting up now
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'guestbackup' is enabled
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'guestbackup' is setting up now
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'guestbackup' is now up
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'loopback' is now up
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Network device 'lo' link is up
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Network alias 'lo' link is up
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'guestbackup' has link connectivity
Mar 27 01:22:23 OpenWrt daemon.notice netifd: Interface 'loopback' has link connectivity
Mar 27 01:22:23 OpenWrt user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Mar 27 01:22:24 OpenWrt daemon.info procd: Instance https-dns-proxy::instance1 s in a crash loop 429 crashes, 0 seconds since last crash
Mar 27 01:22:24 OpenWrt daemon.info procd: Instance https-dns-proxy::instance3 s in a crash loop 429 crashes, 0 seconds since last crash
Mar 27 01:22:24 OpenWrt daemon.info procd: Instance https-dns-proxy::instance2 s in a crash loop 429 crashes, 0 seconds since last crash
Mar 27 01:22:24 OpenWrt user.notice root: netd: Wait up to 10 seconds for link 0...
Mar 27 01:22:24 OpenWrt user.notice https-dns-proxy: Starting service βœ“βœ“βœ“
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2872] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 13.226.52.69 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2874] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 13.226.52.68 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2875] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 13.226.52.52 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2876] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 13.226.52.32 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2877] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:7800:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2878] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:d800:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2879] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:aa00:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2880] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:d000:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2880] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:4a00:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2881] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:e200:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2882] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:1c00:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2883] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns: 2600:9000:21f2:4000:11:18e6:d580:93a1 has no route out
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2889] N: [wsicli|1|WS/h1/default/manage.alta.inc]: lws_sort_dns_dump: empty
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2891] N: __lws_lc_untag:  -- [wsicli|1|WS/h1/default/manage.alta.inc] (0) 2.506s
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2892] N: connect_client: connecting
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2899] N: __lws_lc_untag:  -- [wsi|0|pipe] (0) 14.079s
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2901] N: __lws_lc_untag:  -- [vh|0|netlink] (1) 14.079s
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:2960] N: __lws_lc_untag:  -- [vh|1|default||-1] (0) 14.078s
Mar 27 01:22:25 OpenWrt daemon.notice rc: [2024/03/26 22:22:25:3258] N: Unilever ctl
Mar 27 01:22:25 OpenWrt daemon.alert rc: run "curl -s -f -4 -m 7 -X POST https://manage.alta.inc/api/device/boot -o /var/run/boot.json -H 'Content-Type: application/json' -d '{ "id": "bcb92300d3d8", "model": "1", "version": "2.0j", "pubkey": "AAAAB3NzaC1yc2EAAAADAQABAAABA
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Network device 'eth0' link is up
Mar 27 01:22:26 OpenWrt daemon.notice netifd: bridge 'br1' link is up
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Interface 'trunkiface' has link connectivity
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Interface 'trunkiface' is setting up now
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.164269] nss-dp 39c00000.dp1 eth0: PHY Link up speed: 1000
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.164830] br1: port 1(eth0) entered blocking state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.164870] br1: port 1(eth0) entered forwarding state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.165693] IPv6: ADDRCONF(NETDEV_CHANGE): br1: link becomes ready
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.166434] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.20: link becomes ready
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.166941] br20: port 2(eth0.20) entered blocking state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.166969] br20: port 2(eth0.20) entered forwarding state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.167561] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.30: link becomes ready
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.168017] br30: port 1(eth0.30) entered blocking state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.168208] br30: port 1(eth0.30) entered forwarding state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.168860] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.40: link becomes ready
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.169328] br40: port 1(eth0.40) entered blocking state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.169571] br40: port 1(eth0.40) entered forwarding state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.171640] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.100: link becomes ready
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.172690] br100: port 1(eth0.100) entered blocking state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.172716] br100: port 1(eth0.100) entered forwarding state
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Interface 'trunkiface' is now up
Mar 27 01:22:26 OpenWrt daemon.notice netifd: 8021q 'eth0.200' link is up
Mar 27 01:22:26 OpenWrt daemon.notice netifd: bridge 'br-lan' link is up
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Interface 'lan' has link connectivity
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Interface 'lan6' has link connectivity
Mar 27 01:22:26 OpenWrt daemon.notice netifd: Interface 'lan6' is setting up now
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.175413] br-lan: port 1(eth0.200) entered blocking state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.175446] br-lan: port 1(eth0.200) entered forwarding state
Mar 27 01:22:26 OpenWrt kern.info kernel: [ 2582.178266] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mar 27 01:22:26 OpenWrt daemon.err odhcp6c[10398]: Failed to send RS (Address not available)
Mar 27 01:22:27 OpenWrt daemon.err odhcp6c[10398]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Mar 27 01:22:27 OpenWrt authpriv.info dropbear[10443]: Child connection from 172.31.20.30:61922
Mar 27 01:22:27 OpenWrt authpriv.warn dropbear[10443]: Failed loading /etc/dropbear/dropbear_ed25519_host_key
Mar 27 01:22:27 OpenWrt user.notice root: netd: Failed, failures: 1
Mar 27 01:22:27 OpenWrt authpriv.notice dropbear[10443]: Pubkey auth succeeded for 'root' with ssh-rsa key SHA256:2K2xJDE2L/SHF61D9sRsJ/8XS0Pn/J1JztUZFBbCJpA from 172.31.20.30:61922
Mar 27 01:22:27 OpenWrt daemon.info procd: Instance https-dns-proxy::instance2 s in a crash loop 430 crashes, 3 seconds since last crash
Mar 27 01:22:27 OpenWrt daemon.info procd: Instance https-dns-proxy::instance3 s in a crash loop 430 crashes, 3 seconds since last crash
Mar 27 01:22:27 OpenWrt daemon.info procd: Instance https-dns-proxy::instance1 s in a crash loop 430 crashes, 3 seconds since last crash
Mar 27 01:22:27 OpenWrt authpriv.info dropbear[10443]: Exit (root) from <172.31.20.30:61922>: Error reading: Connection reset by peer
Mar 27 01:22:28 OpenWrt user.notice https-dns-proxy: Starting service βœ“βœ“βœ“
Mar 27 01:22:28 OpenWrt daemon.alert rc: run "curl -s -f -6 -m 7 -X POST https://manage.alta.inc/api/device/boot -o /var/run/boot.json -H 'Content-Type: application/json' -d '{ "id": "bcb92300d3d8", "model": "1", "version": "2.0j", "pubkey": "AAAAB3NzaC1yc2EAAAADAQABAAABA
Mar 27 01:22:28 OpenWrt daemon.alert rc: Warn: curl -s ... rc: 1792
Mar 27 01:22:28 OpenWrt daemon.warn rc: [2024/03/26 22:22:28:3369] W: reg6 failed
Mar 27 01:22:28 OpenWrt daemon.notice rc: [2024/03/26 22:22:28:4235] N:    /usr/lib/libwebsockets-evlib_uloop.so
Mar 27 01:22:28 OpenWrt daemon.notice rc: [2024/03/26 22:22:28:4238] N: lws_create_context: LWS: 4.3.3-2.0j, NET CLI H1 H2 WS ConMon IPV6-on
Mar 27 01:22:28 OpenWrt daemon.notice rc: [2024/03/26 22:22:28:4241] N: __lws_lc_tag:  ++ [wsi|0|pipe] (1)
Mar 27 01:22:28 OpenWrt daemon.notice rc: [2024/03/26 22:22:28:4243] N: __lws_lc_tag:  ++ [vh|0|netlink] (1)
Mar 27 01:22:28 OpenWrt daemon.notice rc: [2024/03/26 22:22:28:4331] N: __lws_lc_tag:  ++ [vh|1|default||-1] (2)
Mar 27 01:22:28 OpenWrt daemon.notice rc: [2024/03/26 22:22:28:5220] N: __lws_lc_tag:  ++ [wsicli|0|WS/h1/default/manage.alta.inc] (1)
Mar 27 01:22:28 OpenWrt user.notice root: netd: Failed, failures: 2
Mar 27 01:22:29 OpenWrt daemon.notice rc: [2024/03/26 22:22:29:0680] N: callback_unilever: established
Mar 27 01:22:29 OpenWrt daemon.notice rc: [2024/03/26 22:22:29:0684] N: writing connect
Mar 27 01:22:29 OpenWrt daemon.alert rc: run "curl -s -f -6 -m 7 -X POST https://manage.alta.inc/api/device/boot -o /var/run/boot.json -H 'Content-Type: application/json' -d '{ "id": "bcb92300d3d8", "model": "1", "version": "2.0j", "pubkey": "AAAAB3NzaC1yc2EAAAADAQABAAABA
Mar 27 01:22:29 OpenWrt daemon.alert rc: Warn: curl -s ... rc: 1792
Mar 27 01:22:29 OpenWrt daemon.warn rc: [2024/03/26 22:22:29:4431] W: reg6 failed
Mar 27 01:22:29 OpenWrt daemon.notice rc: [2024/03/26 22:22:29:5501] N: writing subscribe: R9WtabxyHcBcuLjdy0Tlk
Mar 27 01:22:29 OpenWrt daemon.notice rc: [2024/03/26 22:22:29:5508] N: writing cfg 0e847e5a0b0014405890835c0e905829
Mar 27 01:22:30 OpenWrt user.notice root: netd: Failed, failures: 3
Mar 27 01:22:30 OpenWrt daemon.notice rc: [2024/03/26 22:22:30:6400] N: writing subscribe: devs/J9O4V9RBm7xKQY8q39FGP
Mar 27 01:22:30 OpenWrt daemon.notice rc: [2024/03/26 22:22:30:6407] N: writing subscribe: site/J9O4V9RBm7xKQY8q39FGP/R9WtabxyHcBcuLjdy0Tlk
Mar 27 01:22:31 OpenWrt user.notice root: netd: Failed, failures: 4
Mar 27 01:22:31 OpenWrt daemon.alert rc: run "curl -s -f -6 -m 7 -X POST https://manage.alta.inc/api/device/boot -o /var/run/boot.json -H 'Content-Type: application/json' -d '{ "id": "bcb92300d3d8", "model": "1", "version": "2.0j", "pubkey": "AAAAB3NzaC1yc2EAAAADAQABAAABA
Mar 27 01:22:31 OpenWrt daemon.alert rc: Warn: curl -s ... rc: 1792
Mar 27 01:22:31 OpenWrt daemon.warn rc: [2024/03/26 22:22:31:5115] W: reg6 failed
Mar 27 01:22:32 OpenWrt daemon.notice rc: [2024/03/26 22:22:32:2655] N: JSON: {"stats":120}
Mar 27 01:22:32 OpenWrt user.notice root: netd: Failed, failures: 5
Mar 27 01:22:33 OpenWrt user.notice root: netd: Failed, failures: 6
Mar 27 01:22:34 OpenWrt user.notice root: netd: Failed, failures: 7
Mar 27 01:22:35 OpenWrt daemon.alert rc: run "curl -s -f -6 -m 7 -X POST https://manage.alta.inc/api/device/boot -o /var/run/boot.json -H 'Content-Type: application/json' -d '{ "id": "bcb92300d3d8", "model": "1", "version": "2.0j", "pubkey": "AAAAB3NzaC1yc2EAAAADAQABAAABA
Mar 27 01:22:35 OpenWrt daemon.alert rc: Warn: curl -s ... rc: 1792
Mar 27 01:22:35 OpenWrt daemon.warn rc: [2024/03/26 22:22:35:5859] W: reg6 failed
Mar 27 01:22:35 OpenWrt user.notice root: netd: Failed, failures: 8
Mar 27 01:22:37 OpenWrt user.notice root: netd: Failed, failures: 9
Mar 27 01:22:38 OpenWrt user.notice root: netd: Failed, failures: 10
Mar 27 01:22:38 OpenWrt user.notice root: netd: cloudflare ret: 0
Mar 27 01:22:38 OpenWrt authpriv.info dropbear[10977]: Child connection from 172.31.20.30:61924
Mar 27 01:22:38 OpenWrt authpriv.warn dropbear[10977]: Failed loading /etc/dropbear/dropbear_ed25519_host_key
Mar 27 01:22:39 OpenWrt authpriv.notice dropbear[10977]: Pubkey auth succeeded for 'root' with ssh-rsa key SHA256:2K2xJDE2L/SHF61D9sRsJ/8XS0Pn/J1JztUZFBbCJpA from 172.31.20.30:61924
Mar 27 01:22:39 OpenWrt user.notice root: netd: Next state: enet_normal
Hi @nico that is strange… I will send you an email so we can troubleshoot and get more info.
-MattH
Hello @Alta-MattH
Thank you so much.
