Anyone using the Shark AV2501AE on Wi-Fi with Alta APs?
I run a small office network built around Alta APs and switches, and I’m considering adding a Shark AV2501AE self-empty robot vacuum to the floor for basic cleaning after hours. The vacuum side seems straightforward, but I’m more concerned about how it behaves on an enterprise wireless setup. Specifically, I’m wondering whether it needs a 2.4GHz-only SSID, whether it supports WPA2-Enterprise or only WPA2-PSK, and if anyone has seen issues with client isolation or band steering causing it to drop off. I also want to keep it off the main VLAN, so I’d like to know if the app setup process requires the phone and vacuum to be on the same subnet. I found some third-party information online about the model but nothing about running it behind Alta gear. If you’ve deployed one of these on an Alta network, what SSID and security settings worked for you, and did you hit any surprises during onboarding?
Still weighing this before buying - the Shark AV2501AE AI Ultra Robot Vacuum Review covers specs but not VLAN or enterprise Wi-Fi behavior. I’m leaning toward a 2.4GHz-only IoT SSID on its own subnet, though I’m unsure the app setup won’t need my phone on that same subnet.
I had no issues connecting a robot vacuum to my Alta Labs AP
obviously most of them (if not all) don’t support enterprise wireless, some don’t support protected frames or WPA3 etc etc
put it on the most basic, legacy security you can: WPA2-PSK, 2.4GHz Only, no management frame protection. Once connected you can enable 5Ghz, management frame protection too and see if it it stays connected.
I have connected a few different model shark vacuums to Alta APs without any problems. This was using WPA2-PSK with the SSID on both 2.4GHz and 5GHz. I haven’t had any disconnections or other problems with the vacuum.
I think you will need your phone on the same subnet for initial set up but I do not think it is necessary after initial set up.
