I ran across this link while trying to plan coverage for a small office patio: Best Outdoor Furniture of 2026. Our setup is a few Alta APs indoors, and we want to extend signal to a courtyard where people sit and work. The tricky part is that the furniture layout keeps changing as we add seating, so line-of-sight to the APs isn’t stable. I’m not sure whether to mount APs higher to clear the furniture or just add another AP closer to the courtyard. The link lists furniture options, but it doesn’t say anything about how materials or placement affect signal, so I’m not treating it as a networking source at all. Has anyone here dealt with outdoor seating areas and AP placement? What worked for keeping coverage steady when furniture moves around? Any tips on mounting height or density would help.
Hi there,
For an outdoor seating area where furniture arrangements frequently change, I would recommend planning the AP placement around the overall coverage area rather than individual seating positions.
A few suggestions:
- Mounting the AP slightly higher can help minimise obstructions from furniture and other objects.
- Try to position the AP where it has a relatively clear line of sight towards the courtyard.
- If the courtyard is separated from the indoor area by walls or glass, consider deploying a dedicated outdoor AP closer to the coverage area rather than relying entirely on an indoor AP.
- Avoid placing the AP too close to large metal objects or other potential sources of RF obstruction.
One question: Are you currently using an outdoor-rated Alta AP, or are you trying to extend coverage using one of your existing indoor APs?
