Alta Labs revolutionizes outdoor WiFi with its new WiFi 6 access point. Expect speeds ranging from 800 to 900 Mbps!
Here is a review and an unboxing of the Alta Labs Ap6 Pro Outdoor!
I installed this access point on my patio in order to have optimal coverage over my entire property. I was able to reach between 800 and 900 Mbs when I had a direct view of the access point. When I was in the front of my class, I only got 50Mbs.
You have to keep in mind that I am only on 5Ghz coverage. I aim to do a speed review on 2.4 GHz with the same device, my Macbook Pro M1 Max.
I am attaching the video of my review and some photos.
Schema
Speed Test 1 (pool)
Speed Test 2 (neighbor)
Speed Test 3 (shed)
Speed Test 4 (parking)
Speed Test 5 (patio)
Hope you like the review and that it helps you decide between buying it or not :smile:
As always, good job Alta Labs for the Outdoor AP6 Pro! :tada:
Very nice review!
