Alta Labs first install
Alta Labs saves the day. I remember my first install in a home that had a problem with the video doorbell constantly going offline and having to reboot.
I removed a long range AP and switched to the AP6-pro and never had an issue since. Having multiple SSID options rectified this problem.
Since then I’ve been hooked, and extremely satisfied with the product line in both commercial and residential projects.
Thanks for sharing and for the support @john1 !
