4 address mode (WDS)
Hello Alta group, I would like to enable the WDS feature on my network. I wanted to know if this feature already exists, and if so, how to enable it on my router or access point?
Unfortunately we do not plan to support WDS mode officially - our automatic mesh should provide wireless backhaul services for any standard scenario. You are free to use ssh and enable/disable wds on specific interfaces, though.
Thank you for your quick response. However, how can I enable and disable it via SSH? Please provide the procedure.
https://help.alta.inc/hc/en-us/articles/26753020799131-How-To-Use-SSH-Keys-For-Management
Once you can ssh in, you can use iw dev to see what interfaces you have, then cfg80211tool $IFACE wds 0 to disable, etc.
If you don’t mind, I’ll try tomorrow.
Can you guide me through this? Is there documentation for the commands? I was able to connect to my AP6-pro access point via SSH. I have two interfaces. I’m requesting assistance.
I’m afraid this isn’t something we document - it’s an unsupported feature but I can give you some tips.
root@Printer:~# iw dev
phy#1
	Interface 55w7hfUl8q
		ifindex 12
		wdev 0x100000002
		addr b6:32:70:29:7d:5f
		ssid My-SSID
		type AP
		channel 120 (5600 MHz), width: 80 MHz, center1: 5610 MHz
		txpower 24.00 dBm
This is an example iw dev output. The interface name in this case is 55w7hfUl8q. So you can use the command cfg80211tool 55w7hfUl8q wds 1 to enable WDS support on that interface. To make this persist, you can add it to your /cfg/post-cfg.sh script.
Thank you for your response.
