3rd Party DHCP Issues
Hey everyone,
Looking to use my own DHCP server (Windows Server 2022 box) - In the the controller, I created the network (VLAN 5) and have tried multiple ways to get the router to listen on 172.16.5.1 and then allow my DHCP server to hand out IP’s. If I dont put the subnet in the network portion of the controller (172.16.5.1/32 for instance), the router doesnt listen on the interface and I cant pass traffic.
Does anyone have a fix for this? Or am I subject to using the DHCP of the Route10?
I don’t think there is a way at this time to disable DHCP server on the Route10 while still using it as the router. You might be able to mess with the pool size or use DHCP snooping/guarding on the switch to force it to your own DHCP server.
