I have 8 Ap6 Pro and 5 8port switches from AltaLabs.
All are a couple months old purchased in phases.
Month or so ago one AP6pro unit died. It was promptly replaced by the distributor. Now, another one has died.
(yes i have gone through the forum and have tried all attempts to review it)
I am a bit worried about the failure rate. Have previously used the same Aruba APs for 10+ years without any hiccups. They just worked. I still have them… pulled them out and replaced the entire network at my office with Alta.
Now I am wondering if i did the right thing.
@Pahila@sysman923 Thanks for raising your concerns! I would like to get more information on both of your failures. I will send you both a direct message to collect RMA #s, purchase info, etc.
You can both rest assured we stand behind our products and their build quality. That is why we offer a standard 2 year warranty. We will be sure to get your replacement units on their way ASAP.
Same thing happens here. I ordered the lunch pack (two AP6 Pro and one S8 Switch) in last Oct. Now one AP is dead and not power on. How should I submit a request to get replacement or refund?
