Hi’
I was wondering if you could use the 10g wan port as a lan port? Can one setup link aggregation with 2 10g ports?
I don’t think link aggregation is supported on the Route10 (right now anyway) but you should be able to just switch the port mode on WAN2 from WAN to Standard. For reference: Route 10, Can WAN2 become a Standard LAN port? - #2 by Alta-Josh
