WI-FI Vlan issue
Hi, we have quite a large setup containing about 40aps with 32 vlans, when we have a ssid setup on the management vlan it works fine with no issues, once we connect it to its corresponding vlan, it becomes extremely slow and unusable,this is only over WiFi and not when using a Ethernet connection. Has anyone experienced anything like this
With that many APs and VLANs, you will definitely want to use the Large (or otherwise not Standard) Network Type on your SSID configuration. Can you at least confirm that you have done that?
Hi,
We tried using the large network but that didn’t seem to help, in total on the entire site there are only around 200 devices, each vlan only manages a couple of clients.
Did you reach out to support yet? They are open right now and would be ready to help debug.
