Switch Firmware 2.3p Released
I’ve been using 10Gtek
Same here.
fiber or dac?
1m DAC.
Well since you all are all here.. do you all ever use RJ45 multi gig sfp? If so what brands do you use on that? I’ve been looking for a set of 4 since I have a large alta switch but honestly @Beaker ‘s problems are making me nervous on rolling that one out..
I use all dac at home just because they’re short runs, but a friend of mine has been running these for awhile with no issue. They are some heap chinese sfp’s Amazon.com: 10GBase LR SFP+ Transceiver - SFP+ to LC Module 1310nm 10km DOM Duplex LC SMF Optical Transceiver Module Compatible with Cisco SFP-10G-LR Mikrotik Ubiquiti UniFi Mikrotik Switch : Electronics
I feel like you might just have a faulty s24, they are pretty good with swapping out faulty hardware.
I wouldn’t be too concerned. I’ve already swapped out DAC’s in the past to confirm the plugs on my end. So I’m certain it’s isolated to the switch.
Are you speaking of N-BASET which supports 1g-10g copper? If so, 10Gtek, I’ve been running this with no issues to report.
Yeah like multi gig rj45 where the sfp has an rj45 on it and it can do 1.25,2.5,5, and 10 gb. I have mostly 10gb Networks but figured if I’m buying the sfps I should buy ones that do everything in case I need them to downgrade or something for a time.
Have at it. It works. I use it strictly for client use at the moment.
Agreed.
Not that it helps anyone who might have run into an issue with their own switches, but this firmware update was pretty uneventful for the switches I have out in the world. Just wanted to provide that as an extra data point
@Alta-MikeD So, we have seen updates for everything else except switches. When are we getting the newest firmware?
Nice to see the excitement for a potential new release! Not sure off hand. I’m personally testing a fix that takes time to reproduce. So far things look promising, but I do not know if it’s planned for the next release, or a subsequent one.
I will ask and follow up. Commenting before asking due to delay.
Hi, I see 2.3q is out for the S48-APOE, can we get a changelog?
Never mind, I found it - Release Notes
