craig
November 23, 2025, 11:12pm
1
I would be very keen if you can include some form of SD-WAN Orchestration between route 10’s. It’d be great if it could create full mesh tunnels between sites etc.
jmszuch
November 24, 2025, 2:21pm
2
Definitely could be handy! Makes me think of this feature request from a little while back as well
So, the Route10 hits a sweet spot with its 10 Gbps performance, SFP+ ports, and overall value. One feature that I think could take the Alta platform even further would be a Software Defined WAN Bonding solution, let’s call it AltaBond for fun.
It could be a native, packet-level SD-WAN bonding solution that works seamlessly with the Route10 and downloadable Alta Control.
The idea is to let users combine multiple WAN links like fibre, 5G, satellite into a single, reliable connection that dynamic…
