Route10 installs a "proto bgp" host route to a LAN access point via the WAN after nightly reboot (AP becomes unreachable)
Hello Alta support,
Two nights in a row, after the automatic nightly reboot, my Route10 has installed a host route that sends all traffic for one of my access points out of the WAN interface instead of the LAN. After that the AP cannot reach the controller and shows as Disconnected, and nothing I do on the AP side fixes it. I don't use BGP or any dynamic routing.
SETUP
- Router: Route10 (IPQ9574/Alta-Route10), firmware 1.5l (OpenWrt 21.02.1, kernel 5.4.213)
- AP firmware: 3.0q (installed during the night of 27 to 28 October); the route appeared on 1.5l / 3.0q, so the
  latest updates did not fix it
- 4 Alta APs plus Alta switches, all cloud-managed via manage.alta.inc
- Affected AP: "APoverloop" (MAC bc:b9:23:00:2d:a8) on the main LAN 10.1.1.0/24 (br-lan)
- WAN: eth4.2009, default route via the ISP gateway (shown below as <ISP-GW>)
- No dynamic routing is configured: /cfg/config.json has no BGP/OSPF/dynamicRouting section,
  and /etc/frr/daemons has bgpd=no (all routing daemons set to "no")
WHAT HAPPENS
Night of 26 to 27 October 2026, around 01:26 CET:
- The Route10, switches and APs all rebooted (presumably a firmware update or scheduled restart).
- Afterwards, this route existed in both the main table and table 1:
    10.1.1.6 via <ISP-GW> dev eth4.2009 proto bgp metric 1
- 10.1.1.6 was the AP's address at that time.
- Result: ARP to the AP worked, but ping, SSH and controller traffic did not, because replies went out of the WAN.
  The AP showed as Disconnected, with LLDP management IP 10.188.0.1 ("Alta Provisional").
- Rebooting and factory-resetting the AP did not help.
- At that moment zebra and watchfrr were running. When I deleted the route, zebra put it back within about 20 seconds.
- Workaround: stop zebra and watchfrr, then run `ip route del 10.1.1.6 proto bgp` (also with `table 1`).
  After that the AP re-adopted normally. I moved it to DHCP; it got 10.1.1.30.
Night of 27 to 28 October 2026:
- The AP got a new DHCP lease, 10.1.1.32, at 01:02 CET.
- The Route10 rebooted at about 01:07 CET.
- Afterwards, exactly the same kind of route existed again, now for the AP's new address, in both main and table 1:
    10.1.1.32 via <ISP-GW> dev eth4.2009 proto bgp metric 1
- `ip route get 10.1.1.32` returned: via <ISP-GW> dev eth4.2009
- Removing the AP from the controller and re-adding it did not help.
- This time no FRR process was running (no zebra, watchfrr or bgpd).
- Deleting the route from both tables was enough. It did not come back, and the AP was reachable again straight away
  (ping 0% loss). After re-adopting, the AP works normally on 10.1.1.32.
KEY OBSERVATION
The route is not a leftover: it follows the AP's current IP address (first .6, then .32). So something on the Route10
seems to create it at boot for this specific AP. Only this AP is affected; the other three APs and the switches are fine.
QUESTIONS
1. What on the Route10 creates host routes with protocol "bgp" (186) when no dynamic routing is configured?
   (FRR, route-swd, the mesh feature, the cloud agent?)
2. Why would it point a LAN device's address at the WAN gateway? Is this AP perhaps registered somewhere
   (e.g. mesh or site-to-site) as a remote device?
3. Could this be related to AltaConnect? The 1.5f release notes mention "Multi-hub AltaConnect with automatic BGP
   configuration", which is the only place I know of where the Route10 creates BGP routes by itself. As far as I know
   I am not using AltaConnect or hubs. Could leftover or automatic AltaConnect state cause this route?
4. Is there a known fix or a firmware update for this? For now I delete the route by hand after every reboot.
Diagnostic commands I used (read-only):
  ip route show proto bgp
  ip route show table 1 proto bgp
  ip route get <AP-IP>
  pidof zebra watchfrr bgpd
  ip neigh | grep <AP-IP>
Update: it happened a third time, and it is not specific to the access point.
Night of 29 to 30 October 2026:
  • The Route10 updated to firmware 1.5m and rebooted at about 01:41 CET.
  • Afterwards there was again a host route via the WAN, in both the main table and table 1:
    10.1.5.33 via dev eth4.2009 proto bgp metric 1
  • This time 10.1.5.33 is NOT an access point. It is a regular wireless client (a phone, randomized MAC
    c2:68:0e:49:76:89) on another VLAN (10.1.5.0/24, br-lan_50).
  • Effect: that phone showed up in the controller with an “Alta Provisional” IP (10.188.126.70), because
    the router’s replies to it (including DHCP) went out of the WAN.
  • Again no FRR process was running (no zebra, watchfrr or bgpd). Deleting the route from both tables
    fixed it immediately and it did not come back.
So the pattern so far (3 times, each time right after a firmware update + reboot):
  • 27 Oct: 10.1.1.6 (AP, main LAN)
  • 28 Oct: 10.1.1.32 (same AP, new DHCP address)
  • 30 Oct: 10.1.5.33 (phone, VLAN 50)
    Each time exactly one LAN host gets a “proto bgp” /32 route pointing to the WAN gateway, in main and table 1.
For now I have disabled “Automatic device updates” until there is a fix, because every nightly update
breaks connectivity for one device.
Questions:
  1. Which process installs routes with protocol bgp (186) on the Route10 when no dynamic routing is
    configured? It happens even when FRR is not running.
  2. Is this related to AltaConnect or to how the Route10 learns client addresses after a reboot?
  3. Is there a fix planned, or a way to prevent it (setting, or a safe cleanup at boot)?
Happy to provide SSH access or a support bundle.
