Route10 Firmware 1.4g Released!
It was not addressed, no, not in my case.
I had to manually edit mwan3 config and disable sticky, only that resolved the issue
how can i do this? do you have a link with more info on the cmds etc..
It also includes the DNS fix
I was experiencing similar symptoms leading up to the complete failure of my locally controlled network just before the holiday weekend.
On top of that, I’m also showing high latency between Alta switch devices just running constant ping. It’s sporadic but nevertheless still present.
Not sure what’s going on..
I am pleased to see that there is now support for adding static routes. However, it only seems to work for IPv4 and not IPv6. Do you plan to address this with the next release? Thanks!
