ROUTE10 FAQs (and answers)
Hello,
I noticed static routing is in the “soon” category of features, what about dynamic routing (BGP)?
Does “IPv6 support” include DHCPv6-PD? Is there a way to define firewall rules using IPv6 prefix variable? (In case the IPv6 prefix changes)
Perfectly normal @Frost Can vary heavily depending on the brand of SFP/SFP+/DAC cable being used.
Ah ok good to know thank you
Is adblocking coming as a feature?
How much memory and internal storage does the device have, and is it possible to reset the device to factory settings after messing with the storage? This seems like a fantastic hardware base but I would like to know what it’s like to run other software on it (custom kernels for the acceleration etc being expected).
Will the Route10 have any advanced Security Featuress like Geo Blocking, Gateway AV, Intrusion Prevention, DLS, etc. What is the feature roadmap and timeline for this product. Thanks!
Will the Route10 have any advanced security features such as Geolocation blocking, gateway antivirus, or Data Loss Prevention?
